althea
Apr 29, 2017Guide
Beamforming and MU-MIMO ??
I notice that "Implicit BEAMFORMING" and MU-MIMO are not enabled by default. Is it a good idea to enable these? Should one or both be enabled? Thanks for any help!
- May 01, 2017
Hello althea
Right now they are disabled by default because of disconnect issues but will be fixed in firmware.
DarrenM
DarrenM
May 01, 2017Sr. NETGEAR Moderator
Hello althea
DarrenM
- altheaMay 01, 2017Guide
DarrenM wrote:Hello althea
DarrenM
Thank you! Do you think we will be alerted when firmware is released that it will fix this issue? It would be good to know when we can enable these.Thanks again!
- dpdurstMay 01, 2017Luminary
Interesting, in the 1.9.1.12 they are both checked on
- Hydro130May 01, 2017Luminary
I did a factory reset when I upgraded to this latest version (no particular reason for the FR, I just hadn't done one for a while, so I figured why not)...
Both of those options were unchecked after the FR.
Were those options checked before you did the uopgrade? If so, I think they would've just remained checked after too.
- DeanoYYZMay 22, 2017Initiate
Has this been fixed in the V1.10.1.2 firmware? The release notes "Fixed few bugs" are not helpful.
- marshymallowMay 22, 2017Apprentice
It's still turned off by default.
I updated new firmware and did a router reset.
Monitoring the wifi drop situation now.
It was still dropping prior to reset.
- DarrenMMay 22, 2017Sr. NETGEAR Moderator
This firmware did not have the fixes for the wifi drops.
DarrenM
- JMU1998May 22, 2017Luminary
Will we be able to use THESE features Beamforming and MUMIMO again in a future firmware?
- DarrenMMay 23, 2017Sr. NETGEAR Moderator
Hello JMU1998
Yes that is being worked on for future firmware.
DarrenM
