althea
Apr 29, 2017Guide
Beamforming and MU-MIMO ??
I notice that "Implicit BEAMFORMING" and MU-MIMO are not enabled by default. Is it a good idea to enable these? Should one or both be enabled? Thanks for any help!
- May 01, 2017
Hello althea
Right now they are disabled by default because of disconnect issues but will be fixed in firmware.
DarrenM
DarrenM
May 01, 2017Sr. NETGEAR Moderator
Hello althea
DarrenM
althea
May 01, 2017Guide
DarrenM wrote:Hello althea
DarrenM
Thank you! Do you think we will be alerted when firmware is released that it will fix this issue? It would be good to know when we can enable these.
Thanks again!
- dpdurstMay 01, 2017Luminary
Interesting, in the 1.9.1.12 they are both checked on
- Hydro130May 01, 2017Luminary
I did a factory reset when I upgraded to this latest version (no particular reason for the FR, I just hadn't done one for a while, so I figured why not)...
Both of those options were unchecked after the FR.
Were those options checked before you did the uopgrade? If so, I think they would've just remained checked after too.
- dpdurstMay 02, 2017Luminary
They should not have been, I haven't been in that area for months and just happen to go there while cruising around after the upgrade and noticed it. I unchecked them either way.
