althea
Apr 29, 2017Guide
Beamforming and MU-MIMO ??
I notice that "Implicit BEAMFORMING" and MU-MIMO are not enabled by default. Is it a good idea to enable these? Should one or both be enabled? Thanks for any help!
- May 01, 2017
Hello althea
Right now they are disabled by default because of disconnect issues but will be fixed in firmware.
DarrenM
Hydro130
May 01, 2017Luminary
I did a factory reset when I upgraded to this latest version (no particular reason for the FR, I just hadn't done one for a while, so I figured why not)...
Both of those options were unchecked after the FR.
Were those options checked before you did the uopgrade? If so, I think they would've just remained checked after too.
dpdurst
May 02, 2017Luminary
They should not have been, I haven't been in that area for months and just happen to go there while cruising around after the upgrade and noticed it. I unchecked them either way.
