althea
Apr 29, 2017Guide
Beamforming and MU-MIMO ??
I notice that "Implicit BEAMFORMING" and MU-MIMO are not enabled by default. Is it a good idea to enable these? Should one or both be enabled? Thanks for any help!
- May 01, 2017
Hello althea
Right now they are disabled by default because of disconnect issues but will be fixed in firmware.
DarrenM
DeanoYYZ
May 22, 2017Initiate
Has this been fixed in the V1.10.1.2 firmware? The release notes "Fixed few bugs" are not helpful.
marshymallow
May 22, 2017Apprentice
It's still turned off by default.
I updated new firmware and did a router reset.
Monitoring the wifi drop situation now.
It was still dropping prior to reset.
