Foxeslink
Oct 13, 2019Aspirant
Best option for my house
Hey, so I have a large home and I want internet in certain areas. My house is Full Wired so I can have the best internet. The problem is I dont know what to Buy. I need 3 aps or Orbi system. Two of then are close and the other one is about 25 meters away. What would you do in my situation? Would you buy 3 access points as I have ethernet ready for then? Or should I invest in orbi system?
- ekhalilMaster
You can have Orbi Router and 2 x Orbi Satellites (Package is called RBK53, RBK43 or RBK23) and use wired backhaul to connect the Satellites to the Orbi Router.
The following might help:
https://kb.netgear.com/000060584/Which-Orbi-WiFi-System-is-best-for-me
- FoxeslinkAspirantI was thinking in RKB50.
That would work seamlessly as they are wired ?- ekhalilMaster
That would work seamlessly as they are wired ?Yes, I have and RBK50 with wired backhaul and it works just fine. I have good wifi coverage all over the house, and at the same time have no dependency on how far the satellite is from the router as I'm using wired backhaul.
