VFMass's avatar
VFMass
Best Practice for RBK50 Router and satellite
I just purchased the RBK50 WiFi router and single satellite extender. I still have dead zones as our business is 12,000 sq/ft on a single level. I currently have the router in a central location and the satellite extender within wifi range in one direction.
Question 1: Is it better to have it further away and connected by ethernet (5e connected via gigabit switch)?
I am most likely going to purchase a second satellite to extend the range.
Question 2: Can a satellite wirelessly piggyback off of the other wireless satellite or can it only connect to the router (as opposed to the satellite)? And/or, should it be hardwired to the satellite (or router) for better connectivity?
Thanks. I wish that Orbi had better documentation for best practices in setting up the network.
  • plemans's avatar
    The Orbi's can daisy chain. Which means satellites can connect to each other.  So it'd go RBR50---RBS50---RBS50
    If you have the option of a wired backhaul, I'd use it. I have all my satellites hardwired in and my orbi setup works great.
    the distance issue is one you can play with a little. Basically they need to be at least 30 ft apart. After that its a matter of spreading them out until you start seeing a decrease in performance. This can changed based up on objects in the area so its something you need to play with.
    • VFMass's avatar
      VFMass
      // So, I could simply add an additional satellite to wirelessly connect to the other satellite. For a wired backhaul, it's OK to connect with switches in between or does it need to be cat 5e directly between RBR50/RBS50 or RBS50/RBS50?
      • plemans's avatar
        Yes you can add an additional satellite and it'll daisy chain back to the main router.
        You can add switches in between Orbi's for connection. I've got a managed switch that was plug and play but some have reported issues with green switches or managed switches.
        https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
