adamsky
Dec 19, 2018Aspirant
Best setup for 1Gbit/s FTTH PPPoE, FRITZ!Box 4040 and Orbi RBK53
I just received my new Orbi RBK53. Can I get some advise how to optimally implement these beauties in my setup. So what's the best option for my 1Gbit/s FTTH (PPPoE), FRITZ!Box 4040 and Orbi RBK53:
- Dec 19, 2018
Frankly, I'd go with a different option, get a good wired router to pair with the Orbi as an AP. The Orbi and Fritz both excel with wifi, not routing.
From your choices, I'd go with #1, the Fritz has got to have better routing than the Orbi. #2 and #3 involve using the Orbi as a router, it might work, but this board is filled with people complaining about Orbi in routing mode, very few complain with it in AP mode.
Dec 19, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Ragar99
Dec 19, 2018Luminary
Furry, what the heck? Do you have some kind of macro that searches for key words and auto replies that Modem Combo spiel of yours?
- michaelkenwardDec 20, 2018Guru - Experienced User
It is called experience and knowing that most problems posted here come down to a handful of issues.
The "two routers on a network" one is far too common. The answer is pretty standard and does not depend on the hardware.
People like FURRYe38 are perfectly capable of writing "macros" using the forum software. Here's one of mine:
Two routers on your network can cause headaches. For example, you can end up with competing DHCP servers and local address conflicts. To avoid that you may need to set the routers up with the right DHCP and IP address settings.
Unless you have specific reasons for using two routers, to create two separate networks for example, it is usually easier to use just one router and then to set up the second router as a wifi access point. Netgear advises this, as does just about every site you will visit.- Ragar99Dec 20, 2018Luminary
If you read the initial post you will see three options, none of which propose a two router solution. The OP clearly understands what a bridged modem, AP, and router are, so what is the point in a generic response?
"two routers on a network" may be a common problem, but it is not relevant here. Rather than clutter every thread with general canned advice why not create stickys?
You complain about someone cluttering up the discussion with boilerplate text that was in response to a message from you that had sweet nothing to do with this discussion, or any discussion.
Oh, the irony.
Perhaps you should spend a bit of time reading the notes on how to use this community.
NETGEAR Community Terms Of Service | Answer | NETGEAR Support
