GeorgeJetson
Jul 07, 2017Follower
Best setup for Orbi with ATT Fiber
Just bought Orbi two unit set up to connect to my AT&T Fiber gateway. I've read several blogs and youtube videos. All have different ideas on how to set this up. Most suggest putting the fiber gatewa...
DarrenM
Jul 10, 2017Sr. NETGEAR Moderator
Hello GeorgeJetson
Its whatever will work best for you if you like or are using alot of the advanced features on the ATT router then you can just disable the wifi on it and then use the orbi as AP.
DarrenM
