alokeprasad's avatar
Mar 22, 2025
Best way to factory reset a disconnected RBR and RBS 50's
Hi all,
I have powered off and disconnected my RBR and 2 RBS 53's.  These were replaced by another (newer) mesh system. The new network is functional.
Unfortunately, before switching over to the new devices, I did not factory reset the RBK53 devices.  They are sitting on my workbench.  I need to erase them before selling them or giving them away..
What is the best way to factory reset and erase all stored information (esp passwords) from those things?  The long press (with a pin) of the reset button has not always worked when I was using the RBK53.  They would pop right back on the network, from what I remember...
Thx.
Aloke
  • plemans's avatar
    Power them on and push and hold reset for 30 seconds. that'll clear them out.
    • alokeprasad's avatar
      alokeprasad
      Mentor
      How do I verify that they are clean after I do that?  Re-attach them to my new (eero) network?
      In the past, when I was using them and tried that, they would accept the password and have the same wifi passwords when they were done powering on. Didn't behave like they were fresh from the factory units.
      Aloke
      • CrimpOn's avatar
        CrimpOn
        When Factory Reset, they return to the WiFi credentials printed on the label (bottom of the case).  Is that what is happening?
