WizardOfToz
Mar 08, 2020Tutor
Beyond Frustrated with NetGear "Support"
I have been in the computer industry for over 30 years and have never seen a company like NetGear that hides behind a pay wall and won't support their products beyond one year. While I certainly und...
WizardOfToz
Mar 08, 2020Tutor
I am on a MacBook so when you download the firmware it puts it as a folder on my computer. I chose the .img file when attempting to update manually and it fails with no message as to why.
Now the router is stuck on 2.5.0.38 while the satellite is upgraded to 2.5.1.8. And since everything appears to be working, I am hesitant to mess with it anymore for fear of it breaking.
I also found out today that NetGear Armor is causing my printer to print out network information on three pages every week when it does it's scan. So add that to the pile of crap that NetGear puts out and you can see why I am seriously thinking about going with a competitors product line.
And to think I just bought a new NetGear modem a few weeks ago in order to help offset the speed degradation from the satellite. Luckily I bought it from Costco so I could return it if I decide that is best.
Mar 09, 2020Guru - Experienced User
Factory reset the RBR and walk thru the Setup wizard with either Safari or Firefox or Opera. This time do not setup Armor or Circle. Go directly in to updating the RBR. You can download the RBRs files again using either browser then unpack the file.
I use Mac MacBook Pro 2008 and 2018 and Mac Mini all the time to update my Orbis.
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
WizardOfToz wrote:I am on a MacBook so when you download the firmware it puts it as a folder on my computer. I chose the .img file when attempting to update manually and it fails with no message as to why.
- WizardOfTozMar 10, 2020Tutor
While I appreciate all of your suggestions, the fact remains that everything was working fine with the current settings for a couple of years before the last two firmware updates. Besides, I shouldn't have to do a factory reset and risk everything breaking because NetGear cannot write and test their firmware properly.
I don't think it is too much to ask that customers have a company support option when just about every other company offers it. If their product is out of warranty then simply state that. But there needs to be some middle ground for when the problem is something like software, especially when the company themselves caused the issue.
They even block all messaging on Twitter! So, you know what I did ... I unfollowed them. I bet if everyone using their products would do the same, we'd get some answers. If not, then I'll just spend my money elsewhere the next time I need networking hardware.
- FURRYe38Mar 10, 2020Guru - Experienced User
Well we can only do so much here in the forums. We all volunteers here and here to help out as best as we can. Yes FW has been problematic. We can troubleshoot until thats exhausted. Then you need to contact support.
All we can do is offer the suggestions already given. Resets are a last resort and a valid trouble shooting step. It would be good to try it and see if this gets your system back online. It works and has helped others. Me included. Also remember to do a backup configuration to file after setting up any router. This will save you time if and when a reset is needed.
We understand your frustrations. Your not the only one to complain about FW updates breaking users systems. You can contact one of the forum moderators if you want to discuss support options. Other than this, hope you find something that works.
Good Luck.
- Retired_MemberMar 11, 2020
WizardOfToz wrote:While I appreciate all of your suggestions, the fact remains that everything was working fine with the current settings for a couple of years before the last two firmware updates. Besides, I shouldn't have to do a factory reset and risk everything breaking because NetGear cannot write and test their firmware properly.
If you feel your problem is with the FW, and it probably is, go find the previous stable version and reload it. Then think about how your came upon the version that gave you problems. NG stopped pushing ALL FW updates awhile back. Now they only auto-push those that contain critical updates. If your system is working, leave it alone. You're right about the factory reset, in MOST cases it should be performed as a last resort such as lost passwords. I've been using the same FW for nealy 6 months and have no desire to update. Why?, because my system works.
I wouldn't put too much value in NG customer service. You'll find that most of ther folks in here are able to provide better help for they have been where you are. Your challenge is to sort thorugh the posts and find those that make most sense and deal with your problem.
Good luck.
- theoakMar 11, 2020Luminary
If the router has not updated, take a backup of the router settings via the Advanced tab.
Download the firmware that the router is on and put that back on the satellites.
You can try factory resetting all Orbi devices at that point if you want. With your backup, you can restore your settings.
Finally - DO NOT HIT UPDATE ;)
Just an idea ...
