hamz1k
Oct 07, 2018Follower
BLINK XT - LIVE VIEW
Hello,
I recently have upgraded my router and WIFI system by purchasing the Orbi WIFI system to replace my Linksys router that wasn't giving enough coverage.
However, since changing over ...
Oct 07, 2018Guru - Experienced User
What FW is currently loaded?
What is the Mfr and model# of the IP modem the Orbi is connected too?
I would contact the Mfr of these cameras to seek additional help and information as well. Maybe some compatibility issues.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
sb9900
Dec 30, 2018Aspirant
I have the same question. Anyone have an answer?
- FURRYe38Dec 30, 2018Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
