IamMightyThor
Jun 01, 2017Guide
Blocked Sites/Keywords on Guest Network
When you set up blocked sites/keywords, does that also block them on the guest network? Also, when you add a trusted IP, does the router cache that IP? If so, how do you clear that cache? I b...
DarrenM
Jun 05, 2017Sr. NETGEAR Moderator
Hello IamMightythor
I will have to check on that and report it as a issue.
DarrenM
IamMightyThor
Mar 21, 2018Guide
