IamMightyThor
Jun 01, 2017Guide
Blocked Sites/Keywords on Guest Network
When you set up blocked sites/keywords, does that also block them on the guest network? Also, when you add a trusted IP, does the router cache that IP? If so, how do you clear that cache? I b...
Mar 21, 2018Guru - Experienced User
Usually since Guest Networks is tied directly to the WAN side, blocking of certain web sites and places isn't a feature of some home routers.
- IamMightyThorMar 28, 2018Guide
someone on the guest network can then still do illegal things and cause you pain with your ISP and other entities.
Not Good!!!
