IamMightyThor
Jun 01, 2017Guide
Blocked Sites/Keywords on Guest Network
When you set up blocked sites/keywords, does that also block them on the guest network? Also, when you add a trusted IP, does the router cache that IP? If so, how do you clear that cache? I b...
Mar 21, 2018Guru - Experienced User
Usually since Guest Networks is tied directly to the WAN side, blocking of certain web sites and places isn't a feature of some home routers.
IamMightyThor
Mar 28, 2018Guide
someone on the guest network can then still do illegal things and cause you pain with your ISP and other entities.
Not Good!!!
