Allenmccloud's avatar
Allenmccloud
Blocked web sites on mobile but not on mac
Since installing my Orbi I cant access some web sites on my mobile iphoneX. On my Mac its ok but on phone blocked. I have checked both phone and Orbi for child safety and everything is off so can't understand. If I go to another wifi spot I can access but not at home. Any one help? Allen
  • FURRYe38's avatar
    Have you setup any IP address reservations for the Mac and iPhone?
    Have you enabled any Circle or Armor freatures on the RBR when you first set it up?
    • Allenmccloud's avatar
      Allenmccloud
      Hi Furrye38
      The firm wear is v2.3.5.30
      The modem is Virginhub3
      No reserved IP addresses
      No Circle set up
      I have checked all safety blocks available on both iphone and router and all are set to off so no sites should be blocked. My friends get the same issue when they log into my wifi. Its only here it happens out and about on other wifi its ok so presume its something here thats causing it in Orbi?
      Allen
      Allenmccloud
      Looks like I have done it. I went on to orbi log in and activated Standard Parental Controls. It seems its the wrong way around when its on its clear when its off it stops sites.
