lebphi
Aug 16, 2019Aspirant
blocker les ports sur orbi rbk23
bonjour,
j'envisage d'acheter un pack orbi rbk23 mais avant je voudrais savoir s'il est possbile de bloquer les ports en sortie.
Je voudrais en fait bloquer par défaut tous les ports à l'exception de quelques uns ( 80, 443, ...)
J'ai regardé dans la doc mais je n'ai pas trouvé comment faire.
Est ce possible ?
merci d'avance
en anglais s'il vous plaît
- lebphiAspirant
I'm considering buying an orbi rbk23 pack but first I would like to know if it's possible to block the output ports.
I would actually like to block by default all ports except for a few ones ( 80, 443, . . . )
I looked in the doc but I didn't find out how to do it.
Is that possible?
thank you in advance - lebphiAspirant
I plan to buy a pack orbi rbk23 but before I would like to know if it is possbile to block the ports output.
I would like to block all ports except for a few (80, 443, ...).
I looked in the doc but did not find how to do it.
Is it possible ?
thank you in advance- FURRYe38Guru - Experienced User
I don't believe blocking ports is a feature of Orbi. You can block devices.
You could I support do Port Forwards to a phantom IP address if you really need to block ports.
