BroDoug's avatar
BroDoug
Guide
Apr 28, 2022
Blue Light Orbi RBS50Yv2 But Not on Map
My Blue Light Orbi RBS50Yv2 was working yesterday and has been a couple of years...
This morning it didn't show on my Map...
Firmware is V2.7.3.22
I have Orbi Router RB50...
2 other satellites shows in the map  with the router...
I have a blue light on Extender but not showing on the map;
What would be the next steps to complete the connection
  • In orbi mode, its the devices themselves (your phone/tablet/etc) that choose which to connect to.
    And give it some time. It sometimes takes device a while to swap. Try going to that location you wanted coverage and see if that device connects/switches to that satellite.
  • plemans's avatar
    Not sure what you're referring to with "blue light". A little better description of whats going on might help.
    Are you able to access it through its ip address (find it in the attached devices list)
    • BroDoug's avatar
      BroDoug
      Guide
      I did the setup of power to the Orbi Extender:
      Power plugged in and did not turn it on...
      Held the Sync Button and pushed power on/off button...
      Power came on...
      Continued to hold sync button until white to blue flash a couple of times...
      Then released the sync button..
      It went through several flashing blue...
       Then blue stayed on steady...
      I checked my app and router shows and two other satellites that I have shows up and are working:
      But nothing on the extender shows up...
      But the blue light on extender stays solid blue...
      Orbi Router is RBR50
      Orbi Exstender is RBS550Yv2
      This had been working for about 3 years until this morning...
      Map usually showed Sat. 2 connected to extender with great speeds...
       Thanks Doug
