Lynxus
Dec 15, 2018Follower
Brand new orbi tri set, None of the satellites connect
Hi Guys,
just got my nice set of expensive Orbi's and they dotn seem to work .. ever.
Followed the instructions 100's of times now and nothing.
The router works, It connects, wifi is gr...
Dec 16, 2018Guru - Experienced User
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
https://community.netgear.com/t5/Orbi/quot-Reverse-quot-Daisy-Chain-issue-any-update/m-p/1653439
https://community.netgear.com/t5/Orbi/Orbi-RBR50-Slow-Wired-WAN-after-2-2-1-210-Upgrade/m-p/1667058/highlight/true#M45881
Also if the system was updated to v210, please do a full factory reset on the Orbi router and satellites and set up from scratch.
Lynxus wrote:
Hi Guys,
The router works, It connects, wifi is great but none of the satellites connect.
All i can find online is "MOVE THEM CLOSER"
Ive got them next to eachother now and they dont work!
I get the pulsing white on everything, press sync, etc and eventually , boom, magenta. No connection.
The App and the System in the browser all show connection failed.
What one earth can I do to get these damn things connect?
Im out of ideas?
Netgear dont appear to have support.
I guess its all going back in the box and refunded at this rate.
Any help would be greatly appreachated.
Whats painful is im actually a network engineer by trade and this is insane!
