Stilts99's avatar
Stilts99
Follower
Jul 21, 2020
Broken Orbi RBS50 Power Adaptor
I have two UK model RBS50s with broken power adaptors. Having gone through the infinite loop of frustration that is Netgear Support, can anyone tell me where/how I might obtain replacements? Thanks in advance
1 Reply
  • FURRYe38's avatar
    Try any online e-tailors like Amazon, eBay, etc.
    You don't have to necessarily have a NG branded supply. You can get a different branded supply as long as the Volts, Amps and size of plug matches the original supply specs.
