Cazman4
Dec 23, 2018Aspirant
BT modem, sky fibre, orbi and Plex
Hi (UK user)
I can’t access my Plex server since moving to Orbi server through SKY. I understand I can’t put SKY Hub in bridge mode so I’m toying with the idea of purchasing a BT modem via eBay...
ekhalil
Dec 23, 2018Master
You can also set Orbi in AP mode, if router functionality is provided by your ISP router and you're happy with the provided routing features.
Cazman4
Then you can’t use a lot of the features and it still didn’t work either when trying to access outside of network.
thanks
