Cazman4
Dec 23, 2018Aspirant
BT modem, sky fibre, orbi and Plex
Hi (UK user)
I can’t access my Plex server since moving to Orbi server through SKY. I understand I can’t put SKY Hub in bridge mode so I’m toying with the idea of purchasing a BT modem via eBay...
Dec 24, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try Option #2...
Cazman4 wrote:
Hi (UK user)
I can’t access my Plex server since moving to Orbi server through SKY. I understand I can’t put SKY Hub in bridge mode so I’m toying with the idea of purchasing a BT modem via eBay. If I do this how easy is the set up or is it a simple plug and play type thing?
I had previously used Airport express and had no issues accessing plex but as orbi is a router I assume that’s why I’m having issues.
Thanks in advance.
