Chr0m0s0me
Dec 29, 2018Initiate
Buffering video when streaming from NAS connected to RBR50 router
Hi there,
Looking for some help with my new Orbi.
I purchased the RBK50 on boxing day. FW is 2.2.1.210.
I have been having problems streaming media from my NAS to my Xbox One. The f...
Chr0m0s0me
Jan 16, 2019Initiate
Just thought I would update incase anyone else ran into this problem. I appreciated the above response but I could tell you didn't read my message (or maybe its just a bot) as many of the questions you asked were in my original post.
Anyway I ended up hard wiring the Xbox One and it solved all the issues.
ekhalil
Jan 16, 2019Master
The following can affect the wireless throughput:
1- MU-MIMO which makes use of multi spatial streams to and from the device: Xbox should support MU-MIMO
2- Implicit Beamforming which allows much better data transmissions boost in the mid-long range device setups
You can find those parameters under >>ADVANCED>>Advanced Setup>>Wireless Settings>>
