Michaelr4
Oct 11, 2019Aspirant
Can’t print when connected to RBR20 network
Whenever I am connected to the Orbi network I cannot print to my wireless printer and I have to choose a different network in order to print how can this be corrected so I can stay on the Orbi network
RedBatman89
Oct 11, 2019Guide
Do you have just the router or do you have the additonal satellite too. Becasue if so I may have an idea. I have an rbk23 unit which is the rbr20 with two satellites and the odd thing is that I noticed that for my router if the printer is connected to a satellite that my router and pc at the moment doesnt recognize then it wont print but if I connect to another satellite it will work.
If you have an RBR 20 and an RBS20 then ping the satellite while connected to the router either wired or wirless via CMD. If its no go then try to do it when both your PC and Printer are connected to the same satellite. If it works then its most liklely due to a sofware bug I have just discovered.
https://community.netgear.com/t5/Orbi/Odd-Ping-bug-I-have-discovered/m-p/1804890#M71368
