Zecapagodeiro's avatar
Aug 31, 2018
Can I add 1 new router + 2 satellites to existing system with all 3 as add ons?
I already have a AC2200 system with one RBR40 router and two RBS40 satellites. If I were to buy additional system with same equipment can they be added onto my existing system where the new router would also work as an additional satellite?
  • FURRYe38's avatar
    The RBRs work only as the main AP, they do not support extending wifi signals like the RBS do.
    • Zecapagodeiro's avatar
      Zecapagodeiro
      Thanks. But if I buy the 2 satellites that come with the new router I can at least add those to my existing system, correct? Seems to be the cheaper way to buying the additional satellites even if you don't use the new router
