Ihavequestions9's avatar
Apr 01, 2020
Can I add an RBS50 satellite to a RBK40 modem?
Hello,
I just got an installed an RBK40 modem with an RBS20 satellite that came with it. I was given two RBS50 satellites and I was wondering if they would work well with the RBK40/RBS20, or do I need to get an RBS20 if I want a second satellite?
Thank you.
    • Ihavequestions9's avatar
      Ihavequestions9
      I thought they might work together, but for some reason the system keeps pushing firmware updates, and even though I wired an internet device to the RBS50, it’s not showing up as a connected device. Am I doing something wrong here?
      • plemans's avatar
        Guru
        Ihavequestions9 wrote:
        I thought they might work together, but for some reason the system keeps pushing firmware updates,-----what system is pushing updates?  and even though I wired an internet device to the RBS50, it’s not showing up as a connected device. -----is the RBS50 properly connected to the CBK40? Am I doing something wrong here?
        what firmware is on the CBK40?
        And on the RBS50?
        If you're updating, always make sure to update the satellites first.
        Are you saying you have the satellites connected back to the router?
        And then devices aren't connecting to the satellite?
        Or not showing on the connected device list?
        Be specific with what you've done, whats going on, and any other details that can help.
