CineConcerts
Mar 21, 2018Follower
Can I assign a device to 5g wireless?
I have a Sonos Bridge and Sonos 5 speaker both connected to my Orbi wireless network. Is there any way I can force them to always be on the 5g and not the 2.4g? Thanks!
st_shaw
Mar 21, 2018Master
Thanks!
The answer is "No" and it has nothing to do with Orbi. Sonos devices do not support 5 GHz wifi. They only support 2.4 GHz WiFi connections.
Also, the purpose of your bridge is to support your Sonos devices on a private mesh network, called Sonosnet. As soon as you plug the bridge (or any one of your Sonos speakers) into your router, Sonos switches to Sonosnet and doesn't use WiFI. The bridge provides an additional mesh node, to help coverage in your house.
When using Sonosnet, you need to set Sonos to use Channel 1 and Orbi to use Channel 11 (or vice versa) on 2.4 GHz. Also, you should not plug more than one Sonos device into Ethernet.
