masemasemase
Nov 05, 2021Aspirant
Can I connect an Orbi RBS350 Satellite to an Orbi RBR20 Router...?
The router (RBR20 - Firmware V2.7.3.22) is running in AP mode.
I also have a hard-wired satellite (RBS20 - Firmware V2.7.3.22) which is running well.
The guy at the store searched online and told me it would work :(
Any help would be much appreciated.
I also have a hard-wired satellite (RBS20 - Firmware V2.7.3.22) which is running well.The guy at the store searched online and told me it would work :(
No. He is incorrect. (i.e. full of s**t)
Check the product data sheet (online)
https://www.netgear.com/images/datasheet/orbi/RBS350.pdf
Page 2 under "What do I need?" Orbi router RBR350.
None of the AX products are compatible with the older 802.11ac product line.
- masemasemaseAspirant
Bugger - thought that would be the case. Should have trusted my gut.
Thanks for replying. I'll stop troubleshooting now and put it back in the box.
Hey CrimpOn. Me again.
Nobody seems to sell the RBS20 anymore. Do you think the RBS50 would work with my RBR20?
All of the original Orbi residential satellites will function with the RBR20 router:
RBS50
RBS40
RBW30
RBS20
RBS40V
Satellites from other product lines are not compatible (Pro, AX, the "10" series, Nighthawk)
