louis00375
Oct 29, 2017Aspirant
Can I disable client SSID on Satellite?
Hi all, can i disable the SSID or even the radio to the client (not to the backhaul radio) of the Satellite if possible?
louis00375
Yes, actually. On bridge is needed for my case. Should I use Orbi? Or I should use other bridge router/equipment instead?
peteytesting
Oct 29, 2017Hero
the orbi will still work as a bridge with its wifi enabled , not sure why you would want to disable its wifi
