louis00375
Oct 29, 2017Aspirant
Can I disable client SSID on Satellite?
Hi all, can i disable the SSID or even the radio to the client (not to the backhaul radio) of the Satellite if possible?
louis00375
Due to the phyiscal limitation, I am not able to have wired connection inside a room. I have to bridge two hub connections into a single network. It will be good to using a powerful equipment to bridge two hub. With mesh design, it even reduce the configuration setting on the satellite side. However, as mentioned, it would be too much radio in a same room. Even though 5Ghz shall not have channel overlap issue, it still have a good practice shutting down a excess radio, which is one of the 5Ghz radio of the satellite device in my case.
peteytesting
Oct 30, 2017Hero
then you have the wrong device , you need a client / wireless bridge / media bridge
