thepro8
Jul 17, 2018Aspirant
Can I do this setup?
I'm using ATT Gigabit Fiber with comes with a Arris Modem/Wifi Router.
The setup i'd like is ATT --> Arris Modem (turn off wifi on it) --> Unmanaged switch --> hard wired ethernet ports, Orb...
tsig
Jul 17, 2018Luminary
the satellites need to be plugged into the router, either directly or with an unmanaged switch between them.
You don't have to run the Orib in AP mode, but you may run into weird issues having two networks.
