thepro8
Jul 17, 2018Aspirant
Can I do this setup?
I'm using ATT Gigabit Fiber with comes with a Arris Modem/Wifi Router.
The setup i'd like is ATT --> Arris Modem (turn off wifi on it) --> Unmanaged switch --> hard wired ethernet ports, Orb...
Jul 17, 2018Guru - Experienced User
If you can't bridge the ISP modem or need to use the ISP modem in router mode, you can use the Orbi in router mode if you want too, just enable the DMZ on the ISP Modem and input the IP address the Orbi router gets from the ISP modem and puit this in the modems DMZ.
- thepro8Jul 17, 2018AspirantI haven’t now setup as:
Att fiber —> att modem/router —> Orbi router —> Netgear unmannagwd switch —>> 2 satalitea and tons of other things connected to switch
The challenge now is the satalitea are’t staying connected vie awired. I can only get 1 wired at a time. Thoughts on how to fix?
