martyfp's avatar
martyfp
Luminary
Jul 03, 2017
Can I lock devices to master/satellite ?
Is there any way to force specific devices to stay locked onto the Router and not switch to the satellite?
I am using a wireless surround sound system (Samsung multiroom) which has four devices all connected via wifi :  TV,  soundbar and two wireless rear speakers.
Before installing Orbi, I had all of these devices separate 5GHz SSID from a single wireless router.
However, now that I am using Orbi, I am finding that  3 of the devices attach to the Router and one device connects to the Satellite.    I am getting occasional sound dropouts which I suspect may be due to this.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello martyfp
    No way to manually force the device to the router you could try re position the satellite and see if the router becomes a stronger signal for that device.
    DarrenM
    • martyfp's avatar
      martyfp
      Luminary
      ok thanks. Interestingly, they are all now connected to the router and all is working OK.
