JDB190's avatar
JDB190
Can I put a thumb drive with music on the Orbi
I have some wifi definitive technology speakers. I had a night hawk ac1900 and I put a thumb drive into the router USB slot and I was able to access the music files on my difinitive tech. Apps.
It didn't work when I put it into the Orbi USB drive. Why can I not access my music files?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello JDB190
    Orbi only supports printers via the usb port at this time.
    DarrenM
    • Bing-Stroller's avatar
      Bing-Stroller
      Luminary
      Yes,
      I am using the standard Firmware V1.12.0.18 and I currently have music and video files on a 16GB PNY thumb drive which is attached to my Orbi router.
      Using VLC Local Network connections I can select READYSHARE from the options which then displays USB_Storage which in turn displays the loaded folders/files.
      Both videos and music play perfectly in VLC.
      I have tried various other USB drives but so far only the PNY drive has worked for me.
      • JDB190's avatar
        JDB190
        Thank you for your response but does it matter if it is a 2.0. Or a 3.0 thumb drive? Thank you for your help.
