WiseSilverWolf
May 15, 2022Tutor
Can I use my Orbi RBK50 and RBS50 with Verizon's 5G Home Internet Modem/Router?
So I just switched from Comcast where I was using a Motorola SB8200 cable modem along with my Netgear Orbi RBK50 Router and 1 RBS50 Satellite as a mesh system in my house but I was wondering if I cou...
- May 15, 2022
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry option #2 first...
Timtech
May 16, 2022Apprentice
Yes, make sure you get the latest firmware.
I have and had the exact same set up as you.
I disable DHCP then set it to passthrough on the new firmware on the 5G.. Then you need to use Port 2 on the Verizon 5G and connect that to the same port as your cable modem use to go though on the Orbi.
I swap back and forth between Xfinity and Verizon now with no changes outside of what I plug into the Orbi as the modem.
