IdkWhatUsername's avatar
Feb 03, 2019
Can I use RBS50 with RBK/RBR 40?
Hey guys, so I ordered I currently have the RBK40 System installed (one router and a satellite). I just ordered an Orbi RBS50 satellite since it was offered on a heavy discount, even lower as the RBS...
  • ekhalil's avatar
    Feb 04, 2019
    You can use RBS50 as a satellite to a RBR40 router.
    The RBS50 in this case will only use 2x2 backhaul antenna (out of the 4x4 that RBS50 is capable for) since the RBR40 only supports 2x2 backhaul.
