Dogzelda
Dec 29, 2018Follower
Can I use telnet through Orbilogin.com?
I have my Orbi system set up as an Access Point behind my U-verse router. I can not access the system through 192.168.1.1. Is there a way to use the telnet features through Orbilogin.com? If not, doe...
ekhalil
Dec 29, 2018Master
This is because the U-verse router is another router in your network.
Please disconnect the U-verse router, restart Orbi and log in to Orbi with oebilogin.com.
After that you need either to set the U-verse router into bridged state or set Orbi into AP Mode.
- ekhalilDec 29, 2018Master
Once you disconnect the U-verse router you should be able to login to Orbi using 192.168.1.1 (if you did not change the default DHCP range in Orbi).
