MStech
Feb 08, 2019Aspirant
Can I use two RBS50 in 1 RBR50?
Hi All,
So I bought two RBK50 systems. Each system comes with 1 RBR50 (router) and 1 RBS50 (satellite). My question is, is it possible to use the 2 RBS50 to connect to the 1 RBR50? Or are the R...
- Feb 08, 2019
Hi,
you can have the 2 RBS50s as satellites for one of the RBR50s.
The 2nd RBR50 however cannot be used as satellite.
BBB73
Feb 08, 2019Apprentice
Hi,
- MStechFeb 08, 2019Aspirant
Thanks for the quick reply. Can the 2nd RBR50 be used in AP mode?
- BBB73Feb 08, 2019Apprentice
Hi MStech, yes this is possible but please see ekhalil ’s wise comments in this thread: https://community.netgear.com/t5/Orbi/Orbi-Router-as-a-wired-satellite-access-point-from-another/m-p/1703219#M52122
- Chuck_MFeb 08, 2019Mentor
Additionally you can add more satellites... I bought the same pack as you and recently added a third satellite... works great.
