MStech
Feb 08, 2019Aspirant
Can I use two RBS50 in 1 RBR50?
Hi All,
So I bought two RBK50 systems. Each system comes with 1 RBR50 (router) and 1 RBS50 (satellite). My question is, is it possible to use the 2 RBS50 to connect to the 1 RBR50? Or are the R...
- Feb 08, 2019
Hi,
you can have the 2 RBS50s as satellites for one of the RBR50s.
The 2nd RBR50 however cannot be used as satellite.
BBB73
Feb 08, 2019Apprentice
Hi,
MStech
Thanks for the quick reply. Can the 2nd RBR50 be used in AP mode?
- BBB73Feb 08, 2019Apprentice
Hi MStech, yes this is possible but please see ekhalil ’s wise comments in this thread: https://community.netgear.com/t5/Orbi/Orbi-Router-as-a-wired-satellite-access-point-from-another/m-p/1703219#M52122
- Chuck_MFeb 08, 2019Mentor
Additionally you can add more satellites... I bought the same pack as you and recently added a third satellite... works great.
