dissdigg's avatar
dissdigg
Can my Orbi RBK50 connect to a switch that is connected to modem ?
Hello and thanks in advance.  The issue i am having is that my Orbi mesh rbk50 (router + satellite) for some unknown reason has connection interruptions that last only a brief second but it's enough to knock me out of all my work programs.  Streaming TV or music almost never skip a beat, but the work programs completely close out and then have to restart themselves.
I have done a full reset and setup working with the netgear team.  I have ensured my DOS attack prevention is enabled.  At one point i was blaming the DOS attacks but now i'm not certain.  what is certain is that i get these "hiccups" and it's causing me a lot of issues at work.
My thought was if i could connect a switch to my modem (optimum) i could wire my work computer direct and avoid any interuptions that are coming from the Orbi RBK50.  I would then use another port on the switch to connect my Orbi and do all the normal router and wifi stuff.
Is this possible?   Does anyone else have experience or guidance on these interruptions?   I work and finance and my programs are all very sensitive... Bloomberg, a work VPM, etc.  But even basic webpages get held up when these hiccups happen.  Optimum ensures me it is not them, but is somethign with the router, my wires, etc.   I am at a loss....
thank you kindly, JW
    • dissdigg's avatar
      dissdigg
      Sorry for delay, and thanks all for responses.
      Hardware:  RBR50 (listed this wrong originally, apologies)
      Firmware:  V2.7.2.104
      • vajim's avatar
        vajim
        Master
        lots of discussion about Firmware:  V2.7.2.104
        you may want to consider rolling it back
  • FURRYe38's avatar
    The RBR should be connected directly to the modem. Any LAN switch should be connected after the RBR.
    If the modem has a built in router, Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
  • CrimpOn's avatar
    CrimpOn
    The answer to this question depends entirely on
    • The specific model of ISP device (modem, fiber optical network terminator <ONT>).
      If it is a "plain modem" with no routing capability, then absolutely NO, connecting a switch to it and the Orbi and other devices to the switch cannot work.
      If it is a router, then "maybe", which depends on....
    • Your specific needs. Do you want to forward ports to internal servers?  VPN into the local network from outside? Connect this work computer to devices that are on the Orbi?  Connect devices on the Orbi to the work computer?  Share a printer between the work computer and devices on the Orbi? Play certain internet games?
      If all you want is to have devices use the internet (nothing like the above), then Yes. A switch can be connected to the ISP router.
      The work computer can be on one switch port and the Orbi on a different port.
    • vajim's avatar
      vajim
      Master
      i wonder why it's so hard to discuss the main cause of connection interruptions due to some unknown reason?
