allir
Nov 05, 2017Tutor
Can not create a static route to single IP (Orbi 2.0.0.74)
When adding a static route to a single IP it is not applied. I'm trying to block access to certain IP's by adding static routes and directing them to the local interface on the Orbi. I enter the ...
allir
Nov 05, 2017Tutor
Doesn't work. No matter what you put in other fields, using subnet mask 255.255.255.255 does not work.
My workaround for now is using 255.255.255.252, but it's not a solution as I'm blocking addressess that I don't want to block. I want/need to be able to route a single IP.
TheEther
Nov 05, 2017Guru
Sounds like a bug.
