sjp649
Aug 18, 2019Aspirant
Can not find Orbi wifi
Just got a new Orbi rbk50 system. Plugged it all in and ran it through app. Everything set up perfect, changed SSID/password and had great service even out in my barn....so happy. About 2 hours later, I noticed my phone was back on my ISP 5g instead of my new orbi wifi. Checked on wifi setting and my orbi SSID is no where to be found. I have tried everything I know of at this point but can not figure anything out. I rebooted/reset both the ISP modem and orbi router many times to no avail. The only thing I notice that is interesting is my ethernet port light on ISP modem is not lit all the time, but if I plug that same ethernet from ISP modem into my laptop, I get internet and the light is always on. Also, currently the ring light goes from solid white then will pulse white, go to green then amber then back to white. Please someone point me in the right direction, I'm not well versed on these systems so please try using layman terms for me. Thank you in advance
What devices do you have connected?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). - CrimpOnGuru - Experienced User
sjp649 wrote:Just got a new Orbi rbk50 system. Plugged it all in and ran it through app. Everything set up perfect, changed SSID/password and had great service even out in my barn....so happy. using layman terms for me.
Since the laptop has an ethernet jack, you can plug the laptop into one of the Orbi LAN ports and connect to the Orbi web interface. Since you have two routers (the ISP and the Orbi), it is not clear what IP address the Orbi router will have. If the laptop is Windows, the "ipconfig /all" command (on the CMD: prompt) will show an IP for the "gateway", which is the Orbi.
Open a web browser and enter http://<ip of Orbi>. This should bring up the login screen where the admin ID is "admin" (always) and the password is whatever you set it to during setup (the default is "password", and users are badgered to change it to something more complicated). Note: this is NOT the WiFi password unless you deliberately made them the same.
The web interface will show what is going on with the Orbi in more detail than the "app".
- sjp649AspirantPlugging in Ethernet from orbi to laptop doesn’t do anything. I don’t get any internet. I’m sure that’s because the Ethernet port on isp modem doesn’t stay connected. I have no idea. I’m at a loss
- Anonymous
sjp649 wrote:
Plugging in Ethernet from orbi to laptop doesn’t do anything. I don’t get any internet. I’m sure that’s because the Ethernet port on isp modem doesn’t stay connected. I have no idea. I’m at a lossTalk to us about your modem.
- sjp649AspirantOn my isp modem the Ethernet port 1 where orbi is plugged in will switch by itself from disconnected to 1000M. Even when it’s not disconnected, I still can’t see orbi on WiFi. I also can not do anything by plugging in Ethernet from orbi to laptop, I don’t get an internet connection
