nickfloyd's avatar
nickfloyd
Follower
Sep 30, 2016
Can Orbi be put into bridged mode?
Hey All,   I currently have Netgear Nighthawk X8 Wireless Router with 5 x eeros (set to bridged mode - to avoid double NAT - so essentialy they act as wireless access points).   I have it setup t...
  • peteytesting's avatar
    Sep 30, 2016
    nickfloyd wrote:
    Hey All,
    So my questions are:
    1. Can the Orbi be put into bridged mode so that I can continue using my Nighthawk with link aggregation for my NAS
    2. Is there a better way to set up my network? Like putting the Nighthawk into AP mode - I think I ran into issues with that with the eero because I could not change the default gateway so I effectively had 2 networks 192.168.1.x and 192.168.0.x (bad)
    Any help / thougths would be appriciated!
    Thanks!
    answers
    Q1 . yes the orbi has AP mode for its router so you can run it the way you want to
    q2. . no , use the Nighthawk as a router and the orbi in ap mode with its sat as the Nighthawk is a better router with more features
    pete
