John29466
Sep 26, 2016Follower
Can orbi be used with Netgear routers as access points?
peteytesting
Sep 26, 2016Hero
hi
yes the orbi router has the ability to be put in AP mode so you can connect it to your existing router and also still use its sat , this imho would be the best way to use the orbi at this stage
