AndyWales
Nov 05, 2017Follower
Can Orbi nodes be connected with ethernet?
I’m considering getting an Orbi system to improve WiFi, but have already got Cat5 cables installed between where the nodes would be installed. I presume Orbi would use the ethernet connection in preference to WiFi if I connected it that way - it would nice to be sure though?
Secondly, if I Connect Orbi this way, am I effectively wasting money on an expensive system then not using one of its key functions, or does the seamless WiFi between nodes and similar other functions make it worthwhile? Should I just be using an Access Point or two and configuring them to mirror?
Thanks all
1 Reply
- DarrenMSr. NETGEAR Moderator
Ethernet backhaul is a feature that is coming in the future on orbi but not currently available.
DarrenM
