Vobuai
Apr 08, 2017Follower
Can Orbi router work alone without satellite?
Hi I just want to know if Orbi router can work alone without the satellite or not? Currently I am placing the router in living room and the satellite in bedroom. I want to switch-off the satellite a...
- Apr 08, 2017
Yes, router-only is a supported configuration.
Any devices that were previously connected to the satellite should (eventually) auto-reconnect to the router.
If you are doing it exclusively for EMF reasons, though, it might be worth pointing out that the radiation generated (and absorbed by the human body) by cell phones and towers, radio stations, plane transponders, and the Sun already so grossly exceeds wifi's maximum that there is absolutely no risk in that regard.
Rodney
rhester72
Apr 08, 2017Virtuoso
Rodney
