jblakely
Dec 18, 2018Follower
Can Orbi satellite get info via wired ethernet (not just wired backhaull)?
To Netgear re RBK 44
I have a celing mounted Wi-Fi Access Point, WNDAP360 which is old and doesn't cover my entire home of 6,000 square feet. I am having trouble as it won't update the firmware a...
Dec 18, 2018Guru - Experienced User
Yes it can:
Do you have any ethernet switches in use in the house? If so, Mfr and model# of these switches.
