phucnh06024
May 29, 2017Initiate
Can Orbi wall plug connect to Orbi RBK50?
Dear Netgear community, I have a silly question for y'all. Can Orbi wall plug AC2200 connect to Orbi RBK50 AC3000? I need an extra one for my backyard, so you know, I don't really need a brick l...
Vmk16
May 29, 2017Star
Yes the orbi wall plug will definitely work with RBR 50 (AC3000)
- phucnh06024May 30, 2017Initiate
Thank you so much, buddy. That's all I need to know before purchasing thou. I personally don't like to make a return so many times. Just did 2 this week for the Asus OnHubs and 3-package of Google Wifi. I got a very poor and unreliable signal from Google, even though I installed OnHubs as the primary point and those 3 as the wired point (I don't use the wireless)
