twocybers
Feb 09, 2017Star
Can satellite WiFi be turned off?
I have two satellite Orbi with all the latest updates. I need the satellites to provide Wired internet connections. I do not need theml for WiFi coverage. Sonos says their audio systems not w...
st_shaw
Feb 09, 2017Master
You should be able to turn off Orbi's radios. Try it and see what happens. It should only take a minute to do.
In any case, Orbi WiFi and Sonos should coexist fine, but you need to manage the channels. I haave 9 sonos compoents working fine with Orbi.
I would recommend you DO NOT connect the Sonos components to WiFi. I would instead use the "sonosnet" configuration and configure Sonos and Orbi to use different 2.4 GHz channels. You should have no interference then.
Just plug one, and only one, Sonos component into the router, or into any hardired connection on the LAN. Sonos will setup it's own invisible mesh network on 2.4 Ghz. You can choose the channel space (1, 6, or 11) via the Sonos Controller App. You need to make sure Orbi and Sonos use different channel spaces. If Orbi uses 40 MHz on the 2.4 band you will only have two choices... Put the orbi on Channel 1 and Sonos on channel 11, or vice versa. I have Orbi on 1 and Sonos on 11 and experience no issues.
twocybers
Feb 09, 2017Star
If I unplug an Orbi unit, they a revice that used wire connected internet to that Orbi will not function - not a good solution.
I have looked and can not find any way to turn the WiFi signal from an Orbi unit off.
As for plugging the Sonos into an Obri - they are in different rooms. Since it is possible to have Sonos connect Wirelessly, that is what I would like. If you are saying connect the Sonos only for purposes of setup to a wire, that is fine. But if you are saying that I need to have my only Sonos box connected by wire to make it work, that is another issue.
Don't I have to put the Sonos and my iPhone on the same channel?
- st_shawFeb 09, 2017Master
twocybers wrote:I have looked and can not find any way to turn the WiFi signal from an Orbi unit off.
You raise several points. Let's address one at a time.
To turn Orbi WiFi off you log into the Orbi GUI. Use a wired computer. Navigate to Advanced, Advanced Setup, Wireless Settings.
Now uncheck the "Enable Wireless Router Radio" checkboxes. There are two of these. One is under "Advanced Wireless Settings (2.4GHz b/g/n)" The other is under "Advanced Wireless Settings (5GHz 802.11a/n/ac)"
- twocybersFeb 09, 2017Star
Soory for slow reply. We had some friends drop in.
you wrote:
st_shaw wrote:You raise several points. Let's address one at a time.
I was aware of the process/options you described. I inadvertantly thought those would turn off the WiFi connection between my base station and the satellites which I had assumed was how internet access went from my Base Station to the satellites.
Thank you for pointing out my error.
Ok, so you only have one sonos component. That's good to know.
However, now it's unclear what you are trying to do. On one hand you say you don't need to use WiFi and ask how to turn WiFi OFF on Orbi. On the other hand you say you would like to connect Sonos wirelessly. These two statements don't make sense.
If you can explain in more detail what you want to do, and what you think isn't working now, maybe I can help.
When I said I do not need WiFi, that was unclear. I have no need for the Orbi system to cover my entire house with WiFi - a lot of the promotional Orbi talk referrs to large areas/houses and getting a WiFi signal into all corners. I have had WiFi in my entire house with say a single Apple Airport Extreme - either the current tall unit or the previous flat unit.
I use the Orbi to provide general WiFi (lots of other options exist that do not have multiple satellites which would be adequate) plus Access Points.
I need to provide ethernet wired connections at two locations in my house - these are places were running cables would be hard. If I put my Router in those locations I would expect to have at best weak WiFi in our bedroom - not good since we have various iOS and tvOS devices which use WiFi. Additionally I have a NAS unit that is connected to the Orbi Base Station which we use for Apple's Time Machine backups.
Now what I want --
I want to have a Play1 placed in a room - think of it as a hallway or foyer. I have an electrical outlet there. There are no COAX, Ethernet or twisted pair connections in that area. If I had the Play1 there, I would play music from my iTunes music library for example while preparing meals. We live in a valley and the radio reception is poor. So being able to listen to say Public Radio via Tune-In would be very nice.
I want to have the typical Sonos experience with a Play1 in that location. Assuming all gets worked out, as phase two, I likely would get two more Play1 units for other areas of our house.
I am sorry I confused you. If this is not clear, please try again
Best option: buy a Sonos Boost, wire it to router, use Play1 wherever you please wirelessly on private Sonos mesh network. Add as many additional Sonos speakers as desired later.
It's still not clear why you cannot do what you want now using Orbi with wifi on. You would need to connect your Play1 to wifi though. Shouldn't be an issue with only one speaker.
