Reputationist
Oct 21, 2017Tutor
Can the R7000 work in bridge mode with the Orbi
I currently own a R7000 but it does not reach to all parts of my home. I am in the market for a mesh type router and wanted to continue to use the R7000...is that possible? If it is, how would I co...
- Oct 21, 2017
Thanks - I am just trying to get some additional coverage by using the equipment I have - maybe a little over use...
peteytesting
Oct 21, 2017Hero
hi
sure you can use the r7000 as normal and just disable its wifi and use the orbi in ap mode for your wifi needs
seeing as your r7000 is connected to something for internet you could however just replace the r7000 and use the orbi as your router and wifi
pete
- ReputationistOct 21, 2017Tutor
I was hoping to use it in bridage mode to the Orbi and have the R7000 connect to my powerline attached devices - will that work - with the Orbi doing its wifi thing and the R7000 connecting in bridage mode to the Orbi and it connecting to the devices on the powerline?
- peteytestingOct 21, 2017Hero
im a little confused as to how you have its setup and the terminology your using
so are you using powerline adapters as well ? when you refer to bridge mode what do you actually mean ? as bridge mode can refer to bridging the router or it can refer to using the wifi to connect one router to another
in reality you shouldnt need the power line adapters with the orbi wifi in place
plz explain your setup in more detail
- ReputationistOct 21, 2017TutorYes - powerline adapters - the bridgemode is using the r7000 as a access point to the internet via the orbi?
