capitanmelao
Dec 27, 2016Guide
Cannot Access orbilogin.com or net
Hello I just did install an Orbi router and its satellite , all goes fine, there is internet and sofar all is working well. the problem now is to get access to the admin page, i saw that it was c...
- Jan 13, 2017
guys i did solve it, I did set the IP of the Orbi to 192.168.1.1, the same IP of the main router and now it is working perfectly, it recoginizes the orbilogin.com and entere also with 192.168.1.1 in the browser, thank you very much!
Mikey94025
Jan 04, 2017Hero
Does orbilogin.com work if the Orbi is in AP mode? Is the OP using their Orbi as their main router or AP mode?
DarrenM
Jan 04, 2017Sr. NETGEAR Moderator
Hello Mikey94024
It may not work with AP if the your main router uses 192.168.1.1 you may need to use the new IP of the AP to access the menus.
DarrenM
- capitanmelaoJan 13, 2017Guide
Ok, the main router uses that IP, what should i do now? I am sorry maybe my question could be basic but i am lost.
- swrtwdrvJan 13, 2017Apprentice
Main router should list IP address assignments by MAC address. Should be able to get IP of Orbi. May be able to set a reserved address for Orbi in the main router so the address doesn't change.
